Old 02-06-2010, 08:31 PM
Default 66 427 Pad Stamp Restamp?
I have a 66 427 block that has me a bit stumped. The block is a 3969942 casting. It looks to be an unmolested 4 bolt main block.
The part that has me stumped is the front pad. At first look, it appears to be a blatant restamp. The VIN area is unaltered but the assembly date and suffix code side of the pad has been ground down and restamped. I got the block from a machine shop who had the block in their inventory for 20 years. At first, I thought someone during an 80's restoration had changed this block from a 390HP to a 450HP by changing the assembly/suffix code but leaving the VIN intact. The part that throws me is it looks to be an original 4 bolt block. If that is the case, I see no reason for a restamp since it should have had the IP code to begin with.
Is it possible that this was a factory restamp? It really does not matter since the car is MIA anyway. I am just curious if Tonawanda would grind a pad down and restamp it if there was an error. I will post pictures ASAP.
Old 02-06-2010, 08:33 PM
Default Re: 66 427 Pad Stamp Restamp?
Old 02-06-2010, 08:35 PM
Old 02-06-2010, 08:37 PM
Old 02-06-2010, 08:38 PM
Old 02-06-2010, 09:43 PM
beater68427 beater68427 is offline
Looks like the pad has been filed down
Old 02-06-2010, 09:44 PM
It has, that is what I am asking about.
Old 02-06-2010, 09:47 PM
Not aware of factory filing them down but im sure it could have gone on, I have a couple that they just gang stamped over mistakes, but have never seen one filed down??
Old 02-06-2010, 10:01 PM
Instead of IP it is stamped 1P. I would check with the Vette guys to see if 1 was ever being used for a I.
Old 02-06-2010, 11:07 PM
Rixls6 Rixls6 is offline
I have a block here that is an LS4 Impala block that has the same type of grind down and restamp, with what looks to be correct Tonawanda characters.
I mean who would restamp a block and make it an Impala 345 horse motor?
I've seen others also that I believe are factory restamps.
Far as the 1P stamping, who knows, but like Charley says, check with the Vette guys.
