Old 02-03-2010, 01:08 AM
Default Old wiring harness tach lead
Can you all check your stash of old under dash wiring harnesses? I need a minimum of 3-4' of the brown tach lead wire as found on 70 Chevelles complete with the coil terminal and black rubber molded on firewall bulkhead intact. Please see what you can come up with as this has been about the only wire I cannot make. Thanks in advance.
Rick
