Old 01-31-2010, 09:48 PM
XXXGoldL34M20's Avatar
Default Build sheet codes + breakdown for 1970 Chevelle SS
i recently went through all the websites to search the codes and breakdowns of the build sheet. a lot of web sites like Dales Chevellestuff.com and searches from this super car site and Team chevelle etc... did help me crack down quite a few of the codes. a lot of the codes i already knew but some i just cant figure out or kinda of know but want to confirm.
here is a list of the Codes from each box i would like to break down,any help would be much appreciated.
1- Sequence number CO8097TON372 (just want to know what the "C" letter means)
2- Ign Key "0" it looks as though it continues from the sequence number but under ignition key but what does the "0" mean ?
8- Body number AT426644 AT=Atlanta is the other number on my frame ?
11- Frame XU-R what does "R" mean ?
12- Steering knuckle AS ?
18-Carb GG ?
20-Exaust CAA ?
22-Vac Fittings 046 ?
35-Crank Pulley AB ?
36-V belt groove 1 YE ?
39-V belt groove 4 BG ?
42-Fuel gauge P2 ?
53-Frt end harness XM ?
54-Engine Harness YC ?
56-Hydro Pierce YM ?
58-Htr hse inlet 926 ?
59-Htr hse outlet 929 ?
61-Body frt harness 9390 ?
62-Body lamp harness 8671 ?
64-427 ?
65-I.P. harness BN ?
66-Console harness XTEB ?
67-Inst cluster GK ?
70-Strg column CX ?
74-8165 ?
75+76 -Ctrl arms Front XU XF Rear NHHD ?
77-Carpet front C6299 ?
78-Carpet rear 3466 ?
80-W/hose 3326 ?
81-Shelf trim 2---- ?
85-Pad rear back 5475 ?
90-Ip pads 461 ?
91-Whl covers 323FJ ?
92-Speedo gear+adapter IR F 21 Red What does IR F mean ?
93 Tires L8DS ?
95-EB-CAB PC ?
99-Mounts C-F35 ?
106-Tire Description What does the B-2+2-BB stand for ?
108- in the option what is 133 ?
118-S/F S ?
also under XXX Customer Order there is a 4 Digit Number in hand writing 4783
well thats all of them,i pretty much know what the other codes mean or they are Blank or with slashes.
My Toys
1970 Chevelle SS 454 450 HP LS6 4 Speed Tuxedo Black/Black Vinyl Top/White Stripes
1970 Challenger R/T S.E. 440 390 HP 6-pack 4 Speed Top Banana Yellow/Black Vinyl Top
