Old 01-11-2010, 01:45 AM
ALLZS ALLZS is offline
Default FACTORY COWL HOOD
WAS THE FIREWALL STAMPED DIFFERENT ON A MID YEAR 69 CAMARO FROM FLAT HOOD TO COWL HOOD. LOOKING AT A SO CALLED FACTORY COWL HOOD CAR ?
Old 01-11-2010, 02:41 AM
lzdick lzdick is offline
Default Re: FACTORY COWL HOOD
The commonly referred to "cowl hood" or "Super Scoop hood" is the RPO ZL2 SPEICAL DUCTED HOOD offered as optional equipment on the Camaro (I believe April 1, 1969...10,026 produced). The firewall itself was stamped-out the same on all Camaros.
L.Z.
"...at this point in my life, every day is a Saturday".
Old 01-11-2010, 03:12 AM
David C. David C. is offline
I believe there are a couple dimples above the RH valve cover to locate where the relay was installed, close to the engine ground wire. Look for an extra drilled hole.
Dave C.
Old 01-11-2010, 04:16 AM
Steve Shauger's Avatar
Administrator
The first car produced a ZL2 hood was the late Dec of 68 built ZL1 shipped to Fred Gibb. All SS's and Z28 could have been ordered starting Jan of 69. It was part of COPO 427 car package. This option was rare on Jan and Feb cars, but in later months it became more known and popular. The accelerator linkage accomadates a switch along with a piercing for the wiring harness for the cowl relay/solenoid.
www.vintagecertification.com
Old 01-11-2010, 04:18 AM
Stefano Stefano is offline
Factory ZL2 Camaros also had a wire hole stamped just above the main wire harness fuse panel junction box, on the firewall.
Old 01-11-2010, 08:15 AM
rpoz11's Avatar
rpoz11 rpoz11 is offline
Yenko Premier Member
Funny I never really thought about this before.
Were all Z28's built prior to the ZL2 option all flat hood cars???
And, since the Cowl Hood option was a later release, did the firewall LACK the dimple stamp spots for the relay switch on the early 69 Camaros????
Chavez Ravine
Old 01-11-2010, 08:21 AM
The 3/4 inch hole above the fuse panel junction box hole is for the ducted hood wiring. The 1/2 inch hole below is for tach wiring.
Pic:
http://s74.photobucket.com/albums/i2...cktachhood.jpg
Old 01-11-2010, 09:21 AM
Kurt S Kurt S is offline
http://www.camaros.org/options.shtml#rs
Yes, all pre-Jan Z's were flat hoods. Most post-Jan Z's were also flat hoods too.
Kurt S - CRG
Old 01-11-2010, 09:43 AM
rpoz11's Avatar
Ok, well for me, that explains enuff!
But, what about the firewall?
67, 68, & early 69's????
And how do you answer COPO cars delivered to Yenko on that late evening back late December early January?
Did these cars receive the flat or Cowl Hoods and did their firewalls come with the correct Cowl Induction Relay dimples for he relay???
GM had that firewall tooled up.
So what is the consensus on the dimple markings prior to Jan/Feb release times for the Cowl Hood?
Chavez Ravine
Old 01-11-2010, 05:31 PM
firstgenaddict's Avatar
No COPO's were delivered to Yenko in late dec...it was Fred Gibb and they were ZL1's. not iron block L72's.
As Shauger stated before these were the FIRST 2 Production equipped Cowl Hood cars.
I have never really looked as to whether or not there are any dimples etc on an early car... I have an unmolested 10D 69 Z in my garage I will check this evening.
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
