Old 01-10-2010, 04:12 AM
XXXGoldL34M20's Avatar
Default Harmonic Balancer + Crank Identification Big Block
i have a Harmonic Balancer part #3963532 and a Crank part #7416 with other numbers M010 R020 GMT2 4-74 S-363 P4426.
any help in identification will be much appreciated.
Old 01-10-2010, 04:17 AM
69 Post Sedan's Avatar
Default Re: Harmonic Balancer + Crank Identification Big Block
7416 is a 454 steel crank. With the numbers you gave the casting date appears to be 1974.
Double check the number on the harmonic balancer. I think you have too many numbers.
Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 01-10-2010, 04:27 AM
Kurt
your right,just double checked the last #7 should not be there for the balancer. thank you about the crank.
Old 01-10-2010, 04:36 AM
3963532 is a 8" balancer for a 454.
Old 01-10-2010, 04:44 AM
would both parts work for a LS6 motor?
Old 01-10-2010, 05:16 AM
Yes, I believe so.
You need to get more information on that from someone with more knowledge than me.
I'm sure someone else will chime in.
Kurt
Old 01-10-2010, 03:55 PM
Unreal Unreal is offline
The M010 and R020 are most likely machine notes...10 thou on the mains and 20 thou on the rod journals.
Old 01-10-2010, 10:01 PM
Both your crank & dampner were exclusive to the 1970-71 LS-6 only.
Those parts were available for years later on for service,as your date denotes.
Old 01-11-2010, 02:52 AM
thank you guys,i appreciate the great help here
