Old 01-07-2010, 12:54 AM
DarrenX33's Avatar
Default Steering Column Lockout - Twist Difficulties
Wondering if anyone has encounted a problem with the column twist for the lockout? Mine doesn't seem to be twisting as freely as I'd like. Wondering exactly where the problem might be and if anyone has any advice? Whole thing have to come out? Just spray WD-40 somewhere to free it up? That kinda stuff.
1969 Z28
1972 Corvette
Old 01-07-2010, 01:59 AM
7TL34 7TL34 is offline
Default Re: Steering Column Lockout - Twist Difficulties
Have you checked for lubrication/binding on the backdrive linkage? Might try an adjustment on the linkage. - Dale
Old 01-07-2010, 02:23 AM
DarrenX33's Avatar
Problem is present in the column, without linkage in place.
1969 Z28
1972 Corvette
Old 01-07-2010, 02:30 AM
Smokey Smokey is offline
Is the tumbler shot?
Old 01-08-2010, 10:41 PM
firstgenaddict's Avatar
1. I will assume nothing is rubbing, shroud harness ect?
2. When rotating it by hand does it
a.feel stiff (could be old grease in the collars)
b. gritty sounding (rust or other abrasives in the rotating collars)
c. or is notchy feeling, (worn ign switch or bent actuator rod)
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Old 01-11-2010, 05:50 PM
DarrenX33's Avatar
A) Stiff.
Dripped some oil into the area where the lower bearing is and spent some time just working it back and forth by hand with the rod off. Seems to have helped some. Still would like to know what is going on. I have never had a steering column completely apart aside from pulling out the innards at the top to replace the ignition switch and key buzzer.
1969 Z28
1972 Corvette
Old 01-11-2010, 07:00 PM
IT's not bad to take apart. The 69 Chev Chassis manual covers it. I just completely disassembled cleaned and painted the one for the 69 Z I am restoring.
~JAG~
NCRS#65120
