Old 12-11-2009, 04:26 PM
dlv4540 dlv4540 is offline
Default 1968-69 396-375HP blocks ,#840's, and parts
1969 3955272 4 bolt standard bore block dated L-10-8 with front pad of T0107JH 19W408958 standard bore and has been cleaned and magged. I also have the original 11 to 1 factory pistons and a steel 6223 standard crankshaft. Will sell for $2000. 1968 3965440 4 bolt standard bore cleaned, magged and pressure tested with two sleeves dated E-21-8 with front pad of T0524MQ 18N449843 $1250. I also have a 1969 3955272 4 bolt block standard bore cleaned and magged dated E-23-9 with front pad of T0527JD 19B388171 for $1750. 3919840 square port heads gone through dated I-18-8 and J-22-8 complete $1650. 3919840 square port heads gone through dated F-17-8 and F-18-8 complete $1500. Single 3919840 square port head bare dated C-25-8 and one complete dated C-25-9 for $650 each. I also have a brand new deep groove crank pulley #3955291AB for $75. I can ship if you cannot pick these parts up and can be reached at 330-770-2517 with any questions.
Dennis Vugrinovich
Old 12-11-2009, 05:25 PM
Default Re: 1968-69 396-375HP blocks ,#840's, and parts
I also have a set of 3919840 square port heads both dated A-28-9 cleaned and magged for $1350.
Dennis Vugrinovich
Old 12-12-2009, 03:56 PM
Sale pending on the deep groove pulley.
Dennis Vugrinovich
