Old 11-18-2009, 03:36 AM
sg1747 sg1747 is offline
Default spark plugs?
Just wondering what plug you would use on a 302 that has a true 12.5:1 compression? Right now I'm using racing autolites 133. I don't drive the car alot but the autolites seem to foul the plugs.as soon as change them she gos right up to 7500 rpm.colder plug maybe?
thanks
Old 11-18-2009, 02:20 PM
Chevy454 Chevy454 is offline
Default Re: spark plugs?
If it's the original 186 heads, try an NGK R5670-7 (5034)...
Old 11-18-2009, 04:35 PM
firez firez is offline
I have used NGK XR5 stock #5953 in my 68 Z with no fouling problems.
1968 LOS Rallye Green Z28
Old 11-18-2009, 04:46 PM
The XR5 would be the standard (non-race) version of the R5670 (race) plug...both are good plugs.
Old 11-18-2009, 05:20 PM
whats the 5034
Old 11-19-2009, 04:45 AM
whats the 5034
5034 is the stock number...R5670 is the part number...and -7 is the heat range. Nearly everyone refers to the plugs by the part numbers (which makes sense), but the parts stores I've been to can only look it up by the stock number, so you kinda need to know both...
Old 11-19-2009, 02:26 PM
wheelhop wheelhop is offline
any similar recomendations for an 1969 L78 motor?
Old 11-19-2009, 02:37 PM
I believe there is a whole thread on this a while back. Rob ran down the best choices. Can't find it though.
Old 11-19-2009, 05:02 PM
Well i can tell you one thing all the ngk r5670-7 (5034) got smashed closed.
Old 11-19-2009, 05:07 PM
John, if they are extended tip that may be the problem. I run AC R44's and seem to do just fine.
