Old 11-15-2009, 11:09 PM
70elcaminoLS6 70elcaminoLS6 is offline
Default Question: Steel wheels off a 68 Malibu with disc.
I have three steel wheels off a 68 Malibu with disc. brakes, and I can't seem to find the wheel code on the rim.
There is what appears to be an upside down A to the left of the valve stem on all three, but I see nothing else. The wheel are black and have never been touched. I need one or two more of these rims, but with out a "code" I am lost on what to ask for. Thanks! Randy
Old 11-16-2009, 01:09 AM
Shevelle's Avatar
Shevelle Shevelle is offline
Default Re: Question: Steel wheels off a 68 Malibu with disc.
Randy, they are possibly JK coded wheels. The code is on the inside and you can't see it with the tire mounted. They should have a 6()A3 around the valve stem and two little "bumps" right above the valve stem.
Jacquie
Old 11-16-2009, 02:07 AM
Sebert (Seeb) Sebert    (Seeb) is offline
If your not worried about correctly coded wheels, all you need to know is size and back space/ offset, I'm gonna say you need a 14x6 or 14x5 wheel if it's a base Malibu, the backspace I'm not sure of for that year.
To get the backspace, lay your wheel face down on a flat surface, put a straight edge across the wheel and measure down to the center hub, that'll give you your backspace.
Then you can just look for 14 x6 with a
- backspace.
Sebert (Seeb)
1966 Chevelle SS #s matching 3speed
1969 Chevelle SS 4 speed car
2010 Camaro SSRS
Old 11-16-2009, 04:46 AM
brent396's Avatar
brent396 brent396 is offline
I thought XE 14x6 is chevelle disc
1968 ChevyII 396 375,1969 Camaro 396 375 survivor , 1969 Dynamotion Copo Camaro,1968 L 79 ChevyII ,1969 Camaro 427 ratsness ,1967 Chevelle L79
