Old 11-04-2009, 12:59 AM
Default Aftermarket repo head bolt ???
Any one have any experience with these aftermarket head bolts? I need a set for a 68 396 with correct head markings and have heard horror stories on some imports.
Ground Up Restoration head bolts
Old 11-04-2009, 08:56 AM
Default Re: Aftermarket repo head bolt ???
-----Rick,,,You might also check with Paragon Corvette Parts up here in Michigan as Im sure they have the correct headmark bolts you need as well........Bill S
Old 11-04-2009, 06:19 PM
Thanks Bill. I forgot all about Paragon. Duh!
Old 11-05-2009, 07:26 AM
Rick-
Have you tried AMK?
Tommy Mathison
Old 11-05-2009, 07:42 AM
As far as I could find AMK only sells the short bolt for the big block. I just ordered $1100 worth of hardware from them today and would have put them on the order if they had them. The link above is from Ground Up and I think is made by the same manufacturer who sells to Paragon.
Old 11-05-2009, 06:03 PM
DarrenX33's Avatar
That's where mine came from.
1969 Z28
1972 Corvette
