Old 11-02-2009, 07:58 PM
Lynn Lynn is online now
Default sealing copper head gasket
OK, so it isn't a race car. I am installig a copper head gasket on my BMW turbo car. I run 15 - 18 psi boost. Had a copper head gasket that lasted 5 years before the water sealing failed. Block is "O" ringed and head has receiver groove. I used Yamabond around the water / oil passages. Trying to find something that won't fail, even after five years.
Saw recommendations for Hylomar, but they make three different kinds of RTV. Look here:
http://www.hylomar.co.uk/index.php?o...&Itemid=56
Do I use the 100, 300 or 600, or possibly another Hylomar product? It will only be applied around water / oil passages.
Anyone have experience with Hylomar?
Figured someone on this board was using copper head gasket on something.
Thanks.
Lynn
Doing some more reading, and am now thinking I need the universal blue RF. Anyone with experience?
Old 11-03-2009, 06:04 AM
Default Re: sealing copper head gasket
<font color="blue">These are the 2 we sell the most.
Hylomar (any) is great stuff for little to small gaps, head gaskets, etc ...
Never had a complaint or negative comment on these. </font>
Mike Fabian
Old 11-03-2009, 08:37 AM
Thanks
Old 11-06-2009, 04:22 AM
I had copper gaskets on my biblock from 1999 to 2007 when the engine finally blew up,and had no failure,so maybe my setup worked.I had an O ringed block and non grooved heads with .060" thiick gaskets.I used blue hylomar gasket spray.I put a heavy coat on the block and heads,and a few coats on both siides of the gaskets.I let it set up for about 10 minutes,then layed it all together and torqued the heads down right away.I did add a little tube of cheap stop leak as insurance,but I never had water in the oil no matter how much I accedently overheated it or shot tons of nitrous thru it.Good luck.
Old 11-06-2009, 07:10 PM
Thanks Rich. I had a .078 gasket, and am going to a .062 assuming I don't have valve clearance issues. Will find out tonight. Block is "O" ringed and head has receiver grooves.
