Old 10-16-2009, 11:37 PM
beater68427 beater68427 is offline
Default NHRA F/MP 3??
I have got back to block sanding on Beater (winter Project) you can see a faint F/MP and a 3?? under it on the B pillar Im taking this is a class it was raced in, what was the criteria of this class in late 60's early 70's my Guess is the car was last set up in 1973 alot of the engine parts are 73 including packard wires, I would have thought some better form of wires would have been used at that time??? no clue I was only 5 in 73.....
Old 10-16-2009, 11:43 PM
Chevy454 Chevy454 is offline
Default Re: NHRA F/MP 3??
Modified Production, F...class went 'bye bye' in '81...there's a good story floating around about the protest by the racers @ Indy.
Old 10-16-2009, 11:54 PM
I would guess it was a division 3 car.
Jake is my grandson!!
Old 10-17-2009, 12:11 AM
NHRA F/MP nova back in 1973 was probably 300 inches or so with a tunnel ram. The record back in 1973 was 11.20 at 121.49 set in April. And Kim is right the number 3 probably designates a DIV-3 car (probably a couple numbers after the 3) which is Ohio, Michigan, Illinois, Indiana etc.
Old 10-17-2009, 12:19 AM
Any idea when they went from 3 to 4 digits?
Old 10-17-2009, 12:24 AM
NHRA F/MP nova back in 1973 was probably 300 inches or so with a tunnel ram. The record back in 1973 was 11.20 at 121.49 set in April. And Kim is right the numer 3 probably designates a DIV-3 car which is Ohio, Michigan, Illinois, Indiana etc.
Well the Camaro was originally a 6 so Im wondering then on that 300ci limit your refering to if this car was originally raced as a 6cyl, and took the transformation to a big blocks some time after maybe 73?? Im not sure if you remember from last years posts the car is very interesting and seems to have been raced its whole life but with no real body mods other than a stinger hood. It might have been raced in div-3, early In my original posts I thought it was a east coast car, but it did make its way west early in life, It has some track wins from lions on it and thats quite far from div 3 so same as last year... I just hope I have it finished this winter
Old 10-17-2009, 12:43 AM
Coulda been a 6, or at least in early MP...was like H or something? Sammy, Howie, jump in here...I'm away from my books!
Old 10-17-2009, 01:09 AM
Maybe I stuck the wrong engine in...
Should have been a 6cyl, M22, BE 12 bolt with 4:88's
Old 10-17-2009, 02:13 AM
My division 6 C/SM Modified Eliminator Camaro at Seattle Intl or Pacific Raceways. #6543
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 10-17-2009, 07:26 AM
copo69's Avatar
copo69 copo69 is offline
H/MP was for the 6 cyl's. Lots of little small blocks in M/P. 267 c.i. was popular combo in F in Camaros and Corvettes. I think there may have been some with even smaller displacements. Lots of shoebox Chevys in G with small blocks due to weight/c.i. ratios determining class. Those little motors would scream usually leaving at close to 10K rpm. Modified was really cool when it was a separate eliminator but NHRA screwed 'em. They kept the classes but moved some to Superstock and others to Comp eliminators
