Old 10-16-2009, 08:52 PM
dlv4540 dlv4540 is offline
Default 1969 L78 Blocks and parts
1969 396-375HP 4 bolt block casting number 3955272 dated K-4-8 with front pad of T1113JH 19W356950. The block is standard bore and has been cleaned and magged. I also have the steel 6223 standard crankshaft, 11 to 1 factory pistons and the original 8 inch harmonic balancer all for $2250. I also have a 1969 L78 396 4 bolt block casting number 3955272 dated E-23-9 with front pad of T0527JD 19B388171. The block has been cleaned and magged and is standard bore $1750. 330-770-2517
Dennis Vugrinovich
