Old 09-30-2009, 04:32 AM
406Boy 406Boy is offline
Default Key Buzzer Switch
I am searching for a key buzzer switch for my tilt column. Does anyone know the difference between a switch for tilt and non-tilt columns? Is there really a difference or will they interchange? I am working with a column from a 72 Camaro.
Old 09-30-2009, 08:37 AM
Plowman's Avatar
Plowman Plowman is offline
Default Re: Key Buzzer Switch
You can get them from G.M.
Old 09-30-2009, 07:34 PM
I think the key buzzers are the same,but the ignition harness switch mounted on the tilt column is different then that used on the NON tilt column,in that they flipped them over to accept the terminal plug.
Old 10-01-2009, 06:31 AM
Thanks Guys for the info
