Old 09-07-2009, 05:38 AM
VintageMusclecar's Avatar
Default `67 GM A body shoulder harness clips
Would anyone happen to know where the mounting holes for the shoulder harness clips (<u>not</u> the harness anchor points) are supposed to be located on a `67 A body? I have shoulder belts installed in the Chevelle, but I haven't been able to figure out the correct location for the clips that hold the belts up against the headliner when they aren't in use. (I've already tried to peek under the edge of the headliner, but it's securely glued in place along the edges and I really ain't too keen on the idea of ripping it just to get a look underneath)
Any help would be greatly appreciated.
Eric
Old 09-09-2009, 04:05 AM
1967Z28's Avatar
1967Z28 1967Z28 is offline
Default Re: `67 GM A body shoulder harness clips
The shoulder harness clips that the buckle slips into is not up on the headliner on a '67. It is down toward the leading edge of the upholstered rear/side panel. The shoulder belt will hang basically straight down from the headliner and plug into the clip when not being used. This is for real '67 shoulder belt equipment (which is rare). If you are using '68 and later stuff in the car, then I'm not sure where a suitable place would be under the headliner.
-Jon
Old 09-09-2009, 06:56 AM
Jon;
Thank you.
I retrofitted a set of `70 belts into my Chevelle. I guess I'll have to decide where to locate the clips myself.
Eric
Old 09-09-2009, 04:46 PM
Our '69 elCamino had a clip on the side panel behind the seat. The buckle plugged into it when not in use. I wonder if they are remotely the same?
Old 09-09-2009, 05:46 PM
Jonesy's Avatar
Jonesy Jonesy is offline
Eric
I have a set of the shoulder belt clips that are NOS.
You can have them. The ones I have are black.
Here is a pic of them in my old 67 z/28
Old 09-09-2009, 06:02 PM
Wow.
Thank you.
Eric
Old 09-09-2009, 06:38 PM
Mike;
Please check your PM's.
Eric
Old 09-10-2009, 03:42 AM
1967Z28's Avatar
You're welcome, Eric. The '67 shoulder belt clips won't be useable with the '70 shoulder belt stuff because the belt with the plastic buckle is mounted up on the headliner, which is the reverse of how the '68-'72 Chevelles (and other GM cars) do it.
-Jon
Old 09-10-2009, 04:45 AM
Jon;
I figured that out shortly after Mike posted the pics.
Old 09-10-2009, 05:29 AM
Kurt S Kurt S is offline
http://www.camaros.org/options.shtml#ShoulderHarness
Kurt S - CRG
