Old 09-03-2009, 11:39 PM
sprchvy sprchvy is offline
Default Camaro Nova Parts List Revised
Many prices reduced and many parts added:
Nova/Camaro/Misc. Parts For Sale:
68,69,70/1/2 Nova Only:
(1) Pair of front hubs for 1970 Nova, with bearings and caps, $35.
(2) Pair Original 9.5” front brake drums, 3853549, dated A1870 and A2470, never cut, $40
(3) Complete set of front wheel bearings and races, federal mogul, new, $10
(4) 5-14X6 YB Steel Wheels for 1970 Nova, dated 1-70, $150
(5) 4 1970 Nova Full Wheel Covers, near perfect shape, $25
(6) License Plate Frame for 68-74 Nova, PN 3962910, perfect shape, $25
(7) Lower SB Radiator Hose, Dayco PN 70779, new, $15
(8) Complete Set Upper and Lower Ball Joints, new aftermarket, $35
(9) Complete Sets Upper Control Arm Bushings, new aftermarket, $35
(10) Complete original control arm bolt and shim set, $50
(11) Pair Front Sway Bar Link Kits, new OE style, $10
(12) Pair Front Sway Bar Link Kits, new poly, $20
(13) Original idler arm, 70 Nova, clean, tight, used, $35
(14) Bell Housing for 10.5” clutch, PN 3858403,perfect shape, $50
(15) SBC Cast 4 BBL Intake #6263751 for 1972 350, perfect shape, dated A-21-72, $50
(16) BBC Cast Intake #3931067 for 396/350/325hp and 427/390hp, needs 1 stud chased, D-11-9, $100
(17) Water Pump Pulley for 350 396/325 OR 350 HP, PN 330556, $25
(18) 3 piece bright pedal trim set for 4 speed car, used, nice, $10
(19) Shoulder belt retaining clips, 4 piece set, original, like new $15
(20) Plastic flywheel cover for TH350, new $10
(21) Clear Turn Signal Lens for 70 Nova, new, $10
(22) Pair SBC Motor Mounts, $10
1969 Camaro (some parts may fit Nova as well):
(1) 2 Original visor pivots/supports, bushing, and screws, PN 5716816, OK shape, $20
(1) 2 used front turn signal lenses, like new, no cracks, $10
(2) 1 pair original dual exhaust intermediate hangers, need cleaning, $35
(3) 1 pair original rear quarter window regulators, $35
(4) RH Side OE Window, tinted, no brackets, good shape, $50, dated A25, 6A
(5) 1 original rear view mirror, pivot tight, mirror discoloration, $25
(6) Original,4 Speed Console Shift Trim Plate and plastic tunnel, PN 3949537, $35
(7) Big Block Radiator, 3 core, OE style aftermarket, great shape $50
(8) Complete 4 piece inside window fuzzies for 69 Camaro, standard interior, new, $25
(9) Original 4 blade fan for Camaro, Nova, Chevelle, like new, PN3927791, $20
(10) Original 1” fan spacer for Camaro, Nova, Chevelle, like new, PN 3927792, $20
(11) Original 2 ½” fan spacer and bolts, $20
(12) Used Eaton Fan Clutch, “CO or CC” markings, nice shape, $35
(13) Power Steering bracket set, blasted and coated, $20
(14) Reproduction RC-15 AC Delco radiator cap, like new, $20
(15) 4 piece original front window guide set, $25
(16) 4 speed long linkage rod for column lock actuator, new, $15
(17) 2 piece original front disc brake hold off and prop valve brackets with bolts, $25
Miscellaneous Parts
(1) Pair 333882 Cylinder Heads, dated E976, and F2576, good shape, $100, local
(2) 1102380 63A Alternator, new, $50
(3) 14” Edelbrock Chrome Filter Lid Only, new, $10
(4) 1” Mr. Gasket Holley/Demon Carb Spacer and Heat Shield + studs, new, $10
(5) Fan Bolt Set for 1.5” spacer, used, $10
All good useable or new parts. Photos available. Shipping not included. Some on ebay as well. Thanks for the forum.
Ed Murphy
1969 Hugger Orange X66 4Spd SOLD
1970 Gobi Beige Nova SS Clone SOLD
1967 Jack Douglass One Owner Camaro SOLD
1996 Panzer BMW 850cia
1967 Chevy II Post Car-In process
