Old 09-01-2009, 03:26 PM
dlv4540 dlv4540 is offline
Default Real 1969 L89 Block and Steel 6223 Crankshaft
1969 396 4 bolt block casting number 3955272 dated J-14-8 with front pad stamped T0527KG 19B400425. This is a 396-375HP 4 speed chevelle aluminum headed block. The block has been cleaned and magged and is set up for its final hone and will clean up at 30 over. No damage to the block and is in excellent original condition. I also have the 6223 standard steel crankshaft that will need cleaned up. $3,000 and can be reached at 330-770-2517.
Dennis Vugrinovich
