Old 08-30-2009, 04:38 PM
The Boss's Avatar
The Boss The Boss is offline
Default Pontiac GTO RAM AIR systems for sale.
1968 Upper & lower pan with lid including scoops. Has been sandblasted, primed and painted correct semi black. Very slight pitting where foam seal would be. Not perfect but just enough use showing that nobody will accuse you of buying repro. $950
1971 GTO 455HO Ram Air upper and lower pan. Upper pan has been sand blasted, primed & painted and is in near perfect condition. Lower pan is vintage used, was sitting on the shelf in a body shop for a couple of decades. Has paint haze all over it, but is the correct dual heat riser, with the bracket studs on the vacume pod brackets. Needs to be cleaned & painted but nearly impossible to find. $2,000 for the set.
1972 GTO 455 HO Ram Air setup (different pan than 71) Upper pan is in nice used condition, lower pan is in very nice used condition. Dimples in the pan are different from 71 and there are no studs on the vacume pod because the brackets were eliminated for 72. Correct dual heat riser pan. $2,000 for setup.
Some guys they just give up living
And start dying little by little, piece by piece,
Some guys come home from work and wash up,
And go racin' in the street.
Bruce Springsteen - Racing In The Street - 1978
Old 09-04-2009, 11:43 PM
The Boss's Avatar
Default Re: Pontiac GTO RAM AIR systems for sale.
Nobody?
