Old 08-23-2009, 12:15 AM
dlv4540 dlv4540 is offline
Default 1968 396-375HP Block and Parts
1968 396 4 bolt factory block casting number 3965440 dated E-21-8 with front pad of T0524MQ 18N449843. The block is standard bore with two sleeves and has been cleaned, magged and pressure tested good. I also have the 3919840 heads dated C-11-8 and C-25-8 and they are a stock bare set cleaned and magged. I also have the 6223 standard steel crankshaft and the 3899621 factory bellhousing. $2750 for the package deal and can be reached at 330-770-2517 if interested.
Dennis Vugrinovich
