Old 08-18-2009, 03:41 AM
Musclecarkid Musclecarkid is offline
Default 70 L78 Nova TH400 Kickdown Parts?
Looking for info and pics of TH400 kickdown hardware for a 1970 L78 Nova. What is needed to make the system operate?
Thanks
Kevin
1970 Chevelle Droptop
Period Correct Speed Parts
482 BBC, M22 or TH400?
Day 2 Super Stock Rocks
Old 08-18-2009, 09:47 AM
Default Re: 70 L78 Nova TH400 Kickdown Parts?
Anybody have a 70 L78 Nova with TH400?
Kevin
Old 08-18-2009, 06:00 PM
We have 2 1970 TH400 L78 Novas....some early cars still used the carb mounted kickdown switch. Most will have the switch mounted to the gas pedal under your "right foot".
You can check the wiring harness to make sure you have the connection...let me know if you need more info.
The switch basically completes the circuit to the solenoid on the drivers side of the tranny...I think it is an orane wire.
wilma
Old 08-19-2009, 02:21 AM
kwhizz kwhizz is offline
If your throttle linkage is mechanical.....the switch is mounted on the Carb......If cable.....it should be inside mounted to the gas pedal....
Ken
Old 08-19-2009, 04:01 AM
Wilma, Is the pedal switch and bracket for 70 Nova the same parts found on a 70-72 Chevelle?
Thanks
Kevin
