Old 08-16-2009, 01:15 AM
Alabamcam Alabamcam is offline
Default 67 L78 3911 Carb.
Will bypassing the smog pump affect the performance of the engine/carb.? What was the GM fix for 67 smog pump/Carb backfire?
1967 IPC 4P -
1967 RS Z/28 4L
1967 RS/SS 4K
Old 08-16-2009, 01:28 AM
John Brown's Avatar
Default Re: 67 L78 3911 Carb.
A faulty diverter valve or even a loose vacuum hose to the diverter valve can cause a backfire situation. The carb may not be part of the problem.
John Brown
Old 08-16-2009, 01:52 AM
I am a ways from completing my 67 Z build and I was just curious if the engine would run correctly if I just ran a short bypass hose from the carbs smog inlet to outlet, therefor omitting the smog pump completely?
Pardon for not being specific. I read somewhere that GM experience backfiring problems during 67 for some reason and I have forgotten where I read this or what the corrective action was.
Amen on the Grace
1967 IPC 4P -
1967 RS Z/28 4L
1967 RS/SS 4K
Old 08-16-2009, 01:54 AM
I was hoping that Eric would chime in on this thread too.
1967 IPC 4P -
1967 RS Z/28 4L
1967 RS/SS 4K
Old 08-16-2009, 01:55 AM
oops, I am still learning my way around and I will post in the correct forum for Eric too.
1967 IPC 4P -
1967 RS Z/28 4L
1967 RS/SS 4K
