Old 08-10-2009, 09:05 PM
1969z280 1969z280 is offline
Default What do you think of this pad?
A friend of mine is interested in the following Corvette with this stamp pad. I have my own opinion but, I wanted to see what you guys thought before I taalked to him. Thanks in advance for your opinions, Ed
[image][/image]
... some old Chevrolets and Pontiacs.
Old 08-10-2009, 09:10 PM
Default Re: What do you think of this pad?
Here's a better view.
[image][/image]
Old 08-10-2009, 10:03 PM
m22mike's Avatar
m22mike m22mike is offline
Broch marks look kind of heavy... , compared to a some I have seen.
JMO Mike
Old 08-10-2009, 10:42 PM
MosportGreen66's Avatar
stamped.
Old 08-11-2009, 12:03 AM
PeteLeathersac's Avatar
Broaches and stampings aside, it looks as if much more was decked off it may expose the waterpump bolt hole?.
~ Pete
Old 08-11-2009, 04:29 AM
SBR SBR is offline
stamped.
[/ QUOTE ] I agree
Corvette nut since I was a kid. 67 435s and L88s are my favorites
Old 08-11-2009, 05:19 AM
-----Am always suspect of stampings that are just too straight. As well, if you look at the broaching all the broach-marks are not parallel, and that just cant be.......Bill S
Old 08-11-2009, 05:36 AM
Mr. Chevy's Avatar
Looks Bogus.......
Rich
Old 08-11-2009, 06:44 AM
crash crash is offline
The VIN is stramped into the block and the trans at the same time, so I checked some trans cases for the type of "3" that was used...
I found 2 Muncie main cases as examples...
P9P13(sept 13th 1968) 19S703966
P9H06B(june 6th 1969) 19S731445
Both examples used round top 3"s not flat top 3"s...
I have not seen a Corvette small VIN(1968 and later) use a flat top "3"...
Hope this helps... Crash
Old 08-11-2009, 08:11 AM
jl8dale jl8dale is offline
If you zoom in a little on the vin stamp, I believe I can see the original stamping just above it. Decked and restamped with just the shadow of the original stamp barely visible.
1969 Z/28 Yellow/Yellow - POP
1970 442 Pace Car Convertible
1969 RS/SS Convertible - Black - Special Paint Code
