Old 08-08-2009, 03:05 PM
dlv4540 dlv4540 is offline
Default 1969 L89 Block with 6223 steel crankshaft
1969 396-375HP 4 bolt real L89 block out of a chevelle. The block casting number is 3955272 dated J-14-8 with front pad of T0527KG 19B400425. The block is clean and has been bored 30 over set up for the final hone to drop the pistons in. The 6223 crankshaft is standard but will need cleaned up. $3,000 and can be reached at 330-770-2517 if interested.
Dennis Vugrinovich
