Old 07-31-2009, 10:16 PM
sg1747 sg1747 is offline
Default cowl induction solenoid
I now have 3 cowl induction relays, all have same problem. I have good ground,power to the relay(it clicks) problem is I'm not getting any juice from relay to cowl induction solenoid. But if I run a wire from hot side of relay to the solenoid CI flap works. Any suggestions???
John
Old 07-31-2009, 10:47 PM
William William is offline
Default Re: cowl induction solenoid
The solenoid is grounded by the mounting collar. If the collar has a heavy paint coating it will not be grounded.
Old 08-01-2009, 12:59 AM
its fixed thanks to all
john
