Old 07-23-2009, 04:04 AM
travlnz28 travlnz28 is offline
Default 2 Z28's and a RS/SS Convert.
Three desirable muscle car projects. The prices of each are firm but I do have a package price of $30,500 for all 3. Lots of pics but only to those interested enough to call.
#1 67 RS/SS 4 speed convert. Real car with untouched cowl tag. Originally Tahoe Turquoise, white deluxe, white top. The car had an interior fire mnany years ago. It was purchased in the 90's and a restoration was started. The body shell wa stripped and primed and the subframe was rebuilt with all new components. The body is the most rust-free original panel convertible you will find. there are some small spots of damage but no panel replacement will be necessary. The engine is gone. The 12 bolt was replaced by a 10 bolt at some time in it's life. however, the original Muncie 4 speed with original VIN numbers is there. It comes with most of the parts needed to put it back together. The power top frame is nice. Was a console/gauge car. Nice front cilp with most of the RS parts intact. One of a very few converts that came from the factory with shoulder belts. $11,000
#2 1969 Van Nuys built Z/28. This car still wears much of it's original burgandy paint. The original white paint in the cowl area is the Van Nuys identifier for a Z28. The original stripes are still on the cowl panel and rear deck. It has a CE block, incorrect 4053 carb, incorrect 837 alternator, replacement 116 intake, all correct deep groove pulleys, correct harmonic balancer, correct valve covers, wrong dated 186 heads, correct manual steering Z28 pitman arm. It has a Muncie from another 69 Camaro. It has the original 373 BU 12 bolt posi. It has new repo fenders and a GM NOS cowl hood. It has a RS tailpanel, lights and GM RS rear wiring harness but does not have the hole in the firewall for the vacumn lines for the headlight switch. It is missing the instrument carrier. The console and gauges are nice. Near mint original quarters and doors. Near mint floor and trunk pans. 13,750
#3 70 4 speed RS Z/28. Daytona Yellow car still wearing most of it's original paint. The engine and trans are gone. Still has the original 373 12 bolt posi. Near mint quarters, doors and floors. Some pin holes in the trunk. The 4 speed console is nice. All of the normal Z/28 identifiers are there. I also have enough of the build sheet to identify the Z/28, RS and 4 speed options. $7500
Gregg
760-802-9376
67 Camaro RS/SS 396 Original Drivetrain
70 Chevelle SS 396 Convertible Original Drivetrain
70 Chevelle SS 454 LS5 Survivor Original Drivetrain
70 El Camino SS 396 Original Drivetrain
65 Impala 396/425
65 Triumph TR4 Original Family Owned
Attachments - The Supercar Registry 412277-100_6974.jpg 412276-100_7039.jpg 412275-100_7024.jpg
