Old 07-21-2009, 03:00 AM
sprchvy sprchvy is offline
Default Camaro/Nova Parts-Revised
(Revised)Miscellaneous 1969 Camaro/Nova Parts For Sale:
1969 Camaro:
(1) 2 Original visor pivots/supports, bushing, and screws, PN 5716816, OK shape, $20
(2) 4 front marker lamp bezels, GM resto, PN 3943269, perfect shape, $15
(3) 1 New Header/Trunk Emblem, GM resto, PN 3916654, $10
(4) 2 used front turn signal lenses, need cleaning, $10
(5) 1 pair standard(no bright trim) headlight bezels, good shape, $20
(6) 1 pair original dual exhaust intermediate hangers, need cleaning, $35
(7) 1 complete, original rear taillight wiring harness, perfect shape, $35
(8) 1 pair original rear quarter window regulators, worked when removed, $50
(9) 1 original rear view mirror, pivot tight, mirror discoloration, $25
(10) 1 original black lower dash piece(under column), mounting holes reinforced inside, $10
(11) Original,4 Speed Console Shift Plate and tunnel, PN 3949537, OK shape, $35
(12) 11000834 37A Alternator dated 8K29 (October 29, 1968), $65
(13) NOS LH Rear Wheel Opening Molding, $75
(14) 3858403 Bell Housing for 10.5” clutch, perfect shape, $100
(15) (2) Quarter Windows aftermarket, tinted, no brackets, perfect shape, $100, $25 ship
(16) RH Side OE Window, aftermarket, tinted, no brackets, good shape, $75 local, dated A25, 6A
(17) SBC Cast 4 BBL Intake #6268571 for 1972 350, perfect shape, dated A-21-72, $50
(18) BBC Cast Intake #3931067 for 369/350/325 and 427/390, needs 1 stud chased, dated D-11-9, $90
(19) Big Block Radiator, aftermarket, great shape $100
(20) Big Block, 14” open Element Air cleaner, base clean with small mod, lid nice, $100.
(21) 330556 Water Pump Pulley for 350 396/325 OR 350 HP, $25
(22) Original 2 Piece Prop Valve brackets for 69 Camaro SS with disc brakes, $50
(23) 3 piece bright pedal trim set for 4 speed car, used, nice, $10
(24) Complete 4 piece set inside window fuzzies for 69 Camaro, standard interior, new, $35
(25) Shoulder belt retaining clips, 4 piece set, original, $10
(26) Plastic flywheel cover for TH350, new $15
(27) OE Tie rod adjusting sleeves and hardware for 69 Camaro, excellent shape, original $50
(28) Fuel Pump for BBC, near new, $20
(29) Complete set 1969 Camaro front and rear window trim clips, new, $25
70/1/2 Nova or other:
(30) Pair of front hubs for 1970 Nova, $35.
(31) 4-14X 6 Rally Wheels, (2) XB dated K-1-8, (2) YW dated K-1-9, blasted and coated, $200
(32) 5-14X6 YB Steel Wheels for 1970 Nova, dated 1-70, $250
(33) 1970/1/2 Corvette LT1 Air Cleaner with lid, base great, cover rough, $75
(34) 4 1970 Nova Full Wheel Covers, near perfect shape, $50
(35) Pair 333882 Cylinder Heads, dated E976, and F2576, good shape, $100, local
(36) Pair Original 9.5” front brake drums 3853549, dated A1870 and A2470, great shape. $40, local
(37) License Plate Frame for 68-74 Nova, 3962910, perfect shape, $25
(38) 1102380 63A Alternator, new, $50
(39) 7029207 Quadra-jet dated 12-11-68 for 1969 350/350 4 speed Corvette, needs choke, $150
(40) Original 1970 Nova Mirror 3874242 with gasket and bracket, nice, $25
(41) 1970 Nova Lower SB Radiator Hose, aftermarket, new, $15
(42) SS Rear Trim Panel for 70/1/2 Nova, near new, reproduction, $75
(43) New 70/1/2 Nova SS grille, reproduction, $75
(44) 3 Piece rear axle brake lines (steel) and flex hose(rubber), 70 Nova, new, $30
(45) Edelbrock Performer 1406 600cfm carb, $65, like new
(46) Edelbrock Performer Intake Manifold for SBC, like new, $80
(47) List 1850-2 600 CFM Holley Carburetor, manual choke, good shape, $75
All good useable or new parts. Photos available. Shipping not included. Thanks for the forum.
Ed Murphy
1969 Hugger Orange X66 4Spd SOLD
1970 Gobi Beige Nova SS Clone SOLD
1967 Jack Douglass One Owner Camaro SOLD
1996 Panzer BMW 850cia
1967 Chevy II Post Car-In process
