Old 07-11-2009, 08:18 AM
Woj's Avatar
Woj Woj is offline
Default 1968 Chevelle L79 Numbers Match
I'm posting this for a friend of mine. Here is his description:
This is a true L-79 1968 Chevelle sport coupe and numbers matching. The engine has ES on the block. What you have here is complete car minus the smog equipment. Sheet metal will need to be replace as there are some rust holes in the floor bottom of front fenders and on the lips of quarter panels. The following is what the car has: White Vinyl top, M 21 close ratio 4 speed, F40 special suspension, factory wood wheel, manual rear antenna, tinted front windshield, am radio, parch vinyl interior, heavy duty clutch, power steering, 12 bolt 336 positraction rear end and of course L 79 motor. This car still has the original Muncie shifter. The carpet has been removed to show the floor better. This car is the real deal with documentation to prove it. Asking $6500. Call Toli for more info at: (419) 564-5298. Reasonable hours EST.
I have seen the car, it is original as seen in the pictures. An excellent numbers matching high-perf 327 4spd car. He has the original window sticker and title. Only titled once. Phil Woj.
Thanks SYC.
