Old 07-09-2009, 08:10 AM
Default Muncie rebuild experts
I have a question for the Muncie pro's. First a little history: I had my Chevelle M20 completely rebuilt by a very reputable Muncie guy in Philadelphia . I'm not 100% sure exactly what was done, but it wasn't cheep, and the end result isn't good.
Here's what it does. It seems to take off in 1st gear with no issues, but when I shift it into 2nd, the whole drive train starts shaking real bad. It also does this in 4th gear, but 3rd seems to be better.
Here's another way I can describe it: I can sit in the car, in the garage, with the motor (stock 396) idling at 900 rpm, push the clutch in, and stick it into 4th gear, and hold on!! The whole trans starts to shake, without even letting the clutch out. It does the same thing in second gear. Any suggestions? The trans will be going back to the builder, but I'd like to know what I'm talking about, when I walk into the trans shop.
69 El Camino
69 Nova
C7 Vette
Old 07-09-2009, 08:45 AM
92646 92646 is offline
Default Re: Muncie rebuild experts
Bill, I had a Camaro that when it was parked on an incline you could put the clutch in and it would not roll back and I had a bear of a time getting the car into reverse. It ended up being the bellhousing not being lined up properly causing the input shaft to bind. You might want to pull the trans and check it out on the bench first before you send it out.
Mark Sheppard
Old 07-10-2009, 09:34 AM
I will look at the alignment Mark. I won't have time to pull the trans until mid August, after the Ohio Chevelle show. I'll get back to you then and let you know what happens. Thanks.... BR
69 El Camino
69 Nova
C7 Vette
