Old 07-02-2009, 04:05 AM
scuncio's Avatar
scuncio scuncio is online now
Default Removing A.I.R. tube fittings from manifolds?
Can anyone share a good trick for removing these tube nuts from the exhaust manifolds? A few of the nuts already have the hex head snapped off - on these, should I drill out the ID before using an EZ-out?
Tony
Old 07-02-2009, 05:40 AM
Default Re: Removing A.I.R. tube fittings from manifolds?
FYI, KROIL is a very good penetrating fluid.......
May we assume you've heated the area with a oxy/acet torch ???
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 07-02-2009, 06:44 AM
scuncio's Avatar
Yes, I did heat the area with a torch but two of the fittings will not budge. Unfortunately these are the fittings that have been sheared off so they are even tougher to access. I have been using PB Blaster.
Old 07-02-2009, 06:55 AM
I had that happen to me,and I was able to heat them and grab what was left of the sheared nut with a needle nose....AAAARRRGH!
Old 07-02-2009, 07:01 AM
70 Forest Green Zee's Avatar
70 Forest Green Zee 70 Forest Green Zee is offline
I know the feeling...I had to have 2 of mine drilled out. Fortunately I have a friend that owns a machine shop and he drilled them out for me...I didn't even need to re tap the holes, he did a good job.
1970Camaro Z28
Old 07-02-2009, 07:02 AM
DarrenX33's Avatar
MAP gas and an easy out.
1969 Z28
1972 Corvette
Old 07-02-2009, 06:17 PM
jasonL78 jasonL78 is offline
I was told by an old timer who was a tool and die maker. You can heat up a rusted part and then cool it very quickly with water? I did it with an exhaust pipe and I was able to twist the 2 pipes apart with my hands. So I would think it would work for your manifold also. I guess the theory is when you put the cold water to the hot surface it loosens up the rust? Not sure if you want to give it a try?
Old 07-02-2009, 06:41 PM
ORIGLS6 ORIGLS6 is offline
You might get by with that on steel pipe but I wouldn't try it with cast iron manifolds.
Old 07-02-2009, 07:03 PM
I've had good luck heating manifolds red hot to get the three exhaust studs out. Of course, these weren't valuable. It's the valuable stuff that cracks. Just don't quench the hot part when finished. We used to bury parts in lime to slow the cooling process. With bolts etc, that are rusted, bottomed out or seized, EZ outs usually aren't of much help and as often as not you see them broken off in the hole. Then you have a real mess on your hands. With patience, you can drill the nut out to tap drill size then fish the remaining thread from the nut out with a scriber or small pointed punch. In most cases, it is better to take the part to someone with the equipment and experience. In a desperate case and a valuable part, you can have the piece EDM'd out.
Old 07-02-2009, 07:14 PM
John Brown's Avatar
I've done that many times, and with some pretty valuable manifolds too. Learned the same trick from an old blacksmith. First time I saw him do it I thought the manifold was gonna be toast, but it has worked fine every time I've done it too.
John Brown
