Old 06-23-2009, 06:22 PM
70 ls6 convert 70 ls6 convert is offline
Default 70 chevelle auto to 4sd crossmember
I was just getting ready to put my car back to 4 speed, was wondering if they are different,also the shifter plate that bolts to the trans,and whats the best parts source on the west coast, thanks so much for the help kris..
Old 06-23-2009, 07:01 PM
Geoff Padgett Geoff Padgett is offline
Default Re: 70 chevelle auto to 4sd crossmember
Hello if interested i know of a car in a local wrecking yard that has an original one still ( 72 ss chevelle )in it, that is for sale. You are correct there is a difference in them, the four speed one has an extra bracket welded to the back for shifter mounts.I live in Salinas, Ca and can arrange to ship it to you. I will need to see how much he wants for it, but i think that it would reasonable. Thanks, Geoff.
Cranberry red 1970 L-S6 hardtop
Old 06-24-2009, 12:19 AM
yes i would be interested thank you ..
Old 06-24-2009, 07:38 PM
I may not be using the correct shifter also,im using the one that bolts to a side plate with 2 bolts,does anyone have a picture of the correct shifter,and who sells them ,thank you in advance kris..
Old 06-25-2009, 05:33 AM
Hi,
Just an FYI, convertible crossmembers are narrower than the more common coupes. If you need a convert. 4-speed crossmember, El Camino and station wagon crossmembers are the same width. Good luck finding a 4-speed wagon. Again assuming by your sign on name you have a convert.
Chris
Old 06-27-2009, 08:53 PM
Hi thanks for the info,my convert is an auto,im working on my ls5 hardtop 4sp car,but when i bought it in 1987 the owner of the car couldent keep a 4sd in there, so he put a 400 auto and just left the pedals in the car,i just ordered a new hurst linkage from year one,but i have a question about the seat ,i think its a bench seat car because it doesnt have factory looking seat holes on the inside by the tunnel,i almost had a heart attack last week my buddie thought he found the build sheet in the back seat but it appears to be a strip of paperwith numbers in between the seat and frame,looks like i have to pull the seat appart to get it out,i can see the first line it says car and load number,thanks for the info kris..
