Old 06-17-2009, 11:25 PM
agtw31 agtw31 is offline
Default 4 speed parts with backdrive and M-20
70-72 4 speed linkage with back drive......mostly original but some are repos
this Olds stuff,but should work on Chevy.
pic 2) is the tabs the middle tab is a repo reverse tab....the two on the left are not correct but I think they will work.....the two on the right are not correct but will work....all you need is the inserts from Hurst....also they sell the corrct tabs online
pic 3) is the back drive three of the parts are racebuick repro's and are top shelf....as is the Kliner reverse rod and swivel....it alone cost 75.00....
all the parts were mounted on my Muncie M-21 and worked perfectly
and shifted great....
250.00+ the ride M.O. or paypal...
MUNCIE M-20
older style muncie 2.56 low, 7/8 main pin,needs rebuilt and new input shaft (included )installed ....3 chipped teeth on the old shaft.....
the shifter I have listed elsewhere was on this trans.....
400.00 perfer pick up but I can ship M.O. or paypal
