Old 05-25-2009, 09:09 PM
dlv4540 dlv4540 is offline
Default 1970 396-375HP L78 Warranty Replacement Block
I have a 3969854 4 bolt block dated H-5-70 with a CE code on the front pad. The block has been cleaned, magged, pressure tested and has new cam bearings and freeze plugs installed. The block is standard bore and will remain standard and has been cosmoligned down to prevent any pitting or rusting while it sits. This is an excellent replacment block for a camaro, chevelle or nova application. 330-770-2517 for any questions and can ship the block if you cannot pick it up. Price is $2,000 for the block and I also have some 291 square port heads available as well if needed.
Dennis Vugrinovich
