Old 05-07-2009, 06:52 PM
Default 3970010 block casting
was the same physical casting used for all 4 bolt 3970010 applications in 1970. I think that casting # was used for a long time for many different applications but I'm wondering if there is any difference in the casting or machining that would differentiate an LT1 for the others for a feb 70 block??
3970010 350 69 Corvette Late 69, 4 Bolt Main
3970010 302 69 Camaro Z/28, Late 69, 4 Bolt Main
3970010 350 69-79 Truck 2 & 4 Bolt Main
3970010 350 69-79 Pass, Chevelle, Camaro, Nova, Monte Carlo 2 & 4 Bolt Main
3970010 350 70 Corvette 300, 350, 370 HP Bolt Main
3970010 350 71 Corvette 270, 330 HP, 4 Bolt Main
3970010 350 72 Corvette 200, 225 HP, 4 Bolt Main
Carl
Old 05-07-2009, 09:53 PM
Default Re: 3970010 block casting
To my knowledge they are the same.
Old 05-07-2009, 11:55 PM
Plowman's Avatar
Plowman Plowman is offline
High nickle block!!!!
Old 05-08-2009, 12:26 AM
Nova Jed Nova Jed is offline
Weren't the percentages cast into the block in the timing chain area? Like 010 or 020. Something like that?
Old 05-08-2009, 12:39 AM
ORIGLS6 ORIGLS6 is offline
I have two of those blocks. I'll have to look in the area you're refering to. Never noticed it before.
Old 05-08-2009, 01:01 AM
Im looking at purchasing a block represented as LT1 and dont want to get pinched. You guys are light years ahead of me on this stuff.
Carl
Old 05-08-2009, 09:10 AM
Post a pic of the pad stamping. There are guys on here that can tell you if it is legit.
Old 05-08-2009, 06:04 PM
Jonesy's Avatar
Jonesy Jonesy is offline
Here is a 4 bolt 010 block with the 010 and 020 cast into it.
Old 05-08-2009, 06:26 PM
So would the nickle content markings be different for say the 270 hp vette block?
Carl
Old 05-08-2009, 07:30 PM
Jonesy's Avatar
I believe they would be the same.
