Old 05-03-2009, 04:26 AM
sg1747 sg1747 is offline
Default ground straps
just bought kit for ground straps 2 long 2 short . One short strap is under heater box, going from firewall to sub-frame. Other strap is under windshieldwasher pump and was connected to exhaust manifold bolt is this correct? Now I have 1short 1long leftover what is proper location for remaining straps?
Old 05-03-2009, 05:34 AM
Default Re: ground straps
2 on the firewall going to each valve cover bolt John. They are the long ones. The small one you know about is where you said and there "may" be one more passenger side in the front wheel well from frame to inner fender well. Buy an assembly manual. That will help for these things.
