Old 04-27-2009, 02:49 AM
beater68427 beater68427 is offline
Default Body Bolt Resto A simple How To
I was at the shop today restoring some hardware for the beater and a friend came along for some sunday bench racing, to my surprise he had never seen the simple process I was doing. This gave me a idea on a how to thread. Now I know alot of you out there know how to do this but I thought some might like to see how to and be able to do it themselves.
This is a simple Body Bolt Restoration it can be done for next to nothing. A few items are needed a propane torch, some motor oil, pliers, and a way to clean the bolts, you can use a wire wheel bead blast etc but they need to be clean. Remember to check the threads! here are the items needed.
This is our example bolt in need of a restoration.
The first step is going to be cleaning the bolt you need to do a good job at this, it can be done a number of ways, I chose to bead blast them, remember to clean the threads.
Old 04-27-2009, 02:53 AM
Default Re: Body Bolt Resto A simple How To
The next step is going to be heating the bolt, I like to use a propane torch, a actual cutting torch will heat way too fast and create a "gun blueing effect" heat the bolt to a goldish color first.
Next you want to soak the bolt in the oil.
Old 04-27-2009, 02:57 AM
Remove the bolt from the oil after about 30-45 seconds.
At this point I like to do the whole heating process over without removing the oil.
Old 04-27-2009, 03:07 AM
After you see the oil dissipate resoak the bolt for the last time in the oil.
Remove the bolt after 30-45 seconds.
Old 04-27-2009, 03:12 AM
Let the bolt cool on its own, this is a before and after.
This a comparison with a new bolt out of the box, "upper bolt" and our restored original bolt lower.
Old 04-27-2009, 03:17 AM
For around $4.00 and 2-3 hours on the weekend, you can easily restore your underhood body hardware. I thought this type of post might be informative to some, A "How To Post" if this is the kind of stuff you like please chime in, if not well I just wont do it again.....
Old 04-27-2009, 03:59 AM
TDW TDW is offline
I think it's a great idea. Do more, do more!!!
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 04-27-2009, 05:05 AM
ORIGLS6 ORIGLS6 is offline
Good info. Probably best to use the propane torch vs. the oxy/acetylene? If you overheat the bolts could you possibly compromise the strength?
Old 04-27-2009, 06:03 AM
These bolts are not torqued very high. They are just compressing the body mount rubbers. They really are not getting much stress at all considering their number and size.
Old 04-27-2009, 06:33 AM
Oxygen-Acetylene will heat the bolt quite fast, you would anneal it greatly. (Kinda like sitting in the sun in the desert) the pores in the skin will be very open, also the burn from the torch will effect the finish, Hardness will depend on curing. With propane you will anneal it enough to pull oil in for the finish needed, If you were to rockwell test it, it would be just slightly harder than original using this method.
