Old 04-14-2009, 10:30 PM
69 Post Sedan's Avatar
Default Clutch & Pressure Plate Recommendations
I want to know what your suggestions are for a good Street/Strip clutch setup. The car will be run on the street most of the time but will also be taken to the track every once in a while. I used to run Borg/Warner "Brute Force" but it is not available anymore plus it made the leg shake if traffic wasn't moving.
One suggestion was Centerforce Dual Friction but I have been hearing that if that clutch gets warm it will chatter starting out in first and reverse. I am wondering if the Centerforce II will hold up and not slip.
The motor is a big block 402, approx. 500hp, in the middle of getting a M22, 11" clutch, 3:73 gears with 28" tall tires.
Any help would be great.
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 04-14-2009, 10:34 PM
turbojet427 turbojet427 is offline
Yenko Advertising Member
Default Re: Clutch & Pressure Plate Recommendations
My buddy had a dual friction clutch in a '72 Z/28. The Z had a LS6 454, M22, 410s. I was the passenger to many 7,000rpm 2nd gear burnouts with that car. The clutch had NO issues, but the 8.5" 10 bolt finally did!!!!!
Old 04-14-2009, 10:58 PM
Fast67VelleN2O's Avatar
Centerforce dual friction is all I use.
Day 2 is Life.
Old 04-14-2009, 11:42 PM
I had the dual friction in my 91 Iroc and I did not like it. It did not hold as well I thought it would. The pedal feel was nice though although it was a hydraulic clutch.
Old 04-15-2009, 12:08 AM
How about a Hayes, Zoom etc.? I always ran the stock chevy pressure plate with the L88 disc about 50 years ago. Does those set-ups still work? I like a soft pedal.
Old 04-15-2009, 12:21 AM
69SSZL1's Avatar
69SSZL1 69SSZL1 is offline
Yes, I use the Hays street/strip set up. Clutch pedal is like stock, holds ZL-1 with M/T ET Streets.
Old 04-16-2009, 12:01 AM
I priced this setup on Summit and it came out to $300. Seems a little up there in price. I guess you get what you pay for.
Centerforce II was $185 and the Dual Friction is $270.
Old 04-17-2009, 05:48 AM
Andy Andy is offline
another vote for hays. I have a 510 hp / 500 ft lb 406 in my 67 and the hays holds up to it just fine. the pedal isn't hard to push either, so no sore left leg. don't forget to have it balanced with the flywheel before you put it in there.
Andy
1967 Camaro 406 4 speed
1969 C/10 383 5 speed
1969 D300 318 4 speed
1969 Super Bee 383 4 speed
1972 K/5 350 Turbo 350
1972 Duster 340 727
1974 'Cuda 340 4 speed
Old 04-18-2009, 05:00 PM
Thanks for all the information. I am leaning towards Hays but also getting more information on McLeod.
Kurt
Old 04-19-2009, 02:22 AM
MotionPerformance67's Avatar
MotionPerformance67 MotionPerformance67 is offline
I've had good luck with the dual friction..
<span style="font-weight: bold">I'm stuck in Day2..</span>
