Old 04-12-2009, 07:42 PM
Mr. Chevy's Avatar
Default Camshaft tech. question.....
Does anyone have the the actual specs. ie- lift and duration for a stock camshaft in a 396/350HP motor out of the factory??
Thanks SYC....... Rich
Old 04-12-2009, 08:45 PM
Default Re: Camshaft tech. question.....
'67 # 3883986
Intake opens 56deg BTC
INtake closes 114deg ABC
Int. Lift: .462
Int. Duration: 350deg
Exh opens 110deg BBC
Exh closes 62deg ATC
Exh lift: .480
Exh duration: 352deg
Overlap: 118deg
Verne
PS: This the same cam that was used in the '67 427/390hp motor.
Old 04-12-2009, 09:16 PM
Mr. Chevy's Avatar
Thanks Verne........ Any idea if this was the same specs used through the late 60s, namely 1969??? I'm willing to bet it was....
Rich
Old 04-12-2009, 11:27 PM
Rich,
All my books and references pretty well peter out after '67. sorry. Perhaps someone with later parts books can find out whether the same part number was used through '69.
Verne
Old 04-13-2009, 03:47 AM
That is the same Cam they used in the 1969 L-34 396/350 HP,up until the new 402's came out later on,then they switched over to the #4359.
Old 04-13-2009, 08:35 AM
Mr. Chevy's Avatar
Thanks Guys....
Rich
