Old 04-03-2009, 05:55 AM
1968 nova ss 1968 nova ss is offline
Default 68 nova bb frame mounts
Anybody out know why the part# for 68 BB nova frame mounts is different than the others years.Is the frame mount location on a 68 big block ,use a slightly different hole location or what? chris Teed
Old 04-03-2009, 02:03 PM
jasonL78 jasonL78 is offline
Default Re: 68 nova bb frame mounts
Chris I see you are having some trouble with the early BB frame mounts. I have a picture of my original left 68 BB nova frame mount with the part number 3912597 and the right should be 3912598. I ran into a problem finding the correct motor mount when I did my car. I ended up finding the GM part number and buying it over the counter but it is no longer avaliable from gm. The BB frame mounts are the same as 67-68 camaro but use the SB motor mount. The design was changed for the 69 year do to the motor mount couldn't handle the BB power. This is a link to a site with the frame mount information. If you would like I can post a picture of my frame mount tonight. If you have aftermarket frame mounts this may be your problem I am not sure how good they are?
http://www.pozziracing.com/camaro_engine.htm
Old 04-03-2009, 04:27 PM
Jason,I have the 97 and 98 frame mounts ;was just wondering why the 68 bb used a different part#Thanks ,chris
