Old 03-16-2009, 06:18 PM
Default Dual matched date 750 Holleys
Something just for the old-school dual quad crowd. Recently received fresh restorations from Eric Jackson (VintageMusclecar) a pair of dated Holley 4150 list 6109 750 CFM double pump carbs. These are both dated the same and are 1st week of November 1970 and perfect for that early Day II restoration. These are fully restored, tested and ready to run.
You don't see these carbs pop up very often with original dates still intact since most of these carbs had their air horns lopped off before they were ever even bolted down on an engine. Eric worked his magic on these carbs to make them perform better than original.
$700 for the pair. I will not seperate. Prices do not include shipping. Satisfaction guarantied.
Old 03-16-2009, 06:42 PM
turbojet427 turbojet427 is offline
Default Re: Dual matched date 750 Holleys
Do you have the double feed fuel bowls?
Old 03-16-2009, 08:21 PM
Each bowl (front and rear) has it's own dedicated fuel inlet as opposed to a transfer tube. You can barely see the rear banjo fitting.
Old 03-27-2009, 12:11 AM
Sold. Thanks sYc
