Old 03-15-2009, 07:34 PM
Alss's Avatar
Alss Alss is offline
Default 074 head repair
In my other post regarding oil pressure in my ZL-1 it has been determined that my heads are also in trouble. Water can enter both heat crossover chambers on the heads..this is not good..can this be repaired? The heads will have to come off,.. but the motor is out so now would be a good time. I can feel the hole between the two chambers ..I can do this on both heads if I stick a bent wire just beyond view in the heat port..I was thinking about filling the passage up enough to cover the break using block grout/concrete..may only be the size of a golf ball when done..anyone have experience with this..Thanks
ALbert
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
