Old 03-06-2009, 10:15 PM
1969z280 1969z280 is offline
Default 66 Chevlle SS Opinion
This is the stamp pad from a 66 Chevelle SS that I'm looking to buy. I never had a 1966 and the Protecto-plate shows the same assembly stamp code but does not include the "H". I don't think this should be there. Does anybody know? Thanks, Ed
[image][/image]
... some old Chevrolets and Pontiacs.
Old 03-06-2009, 10:21 PM
Default Re: 66 Chevlle SS Opinion
The H indicates that the engine originally used a Holley carb. I am not sure if it would be on the POP or not.
Old 03-06-2009, 10:45 PM
beater68427 beater68427 is offline
Jason is correct the "H" is holley and is not on the protecto plate this is my 67 plate and efh suffix I also have a 66 edh and the same story.
Old 03-06-2009, 11:33 PM
Tarrytown SS427s Tarrytown SS427s is offline
It's not on the engine suffix part of the POP, but the H for Holley is still present in the upper LH corner of the plate.
Steve
68 Caprice Estate
68 Camaro SS396 4 speed
Old 03-06-2009, 11:47 PM
I wondered what that "H" was for lern something every day
Old 03-07-2009, 02:19 AM
This is a picture of the stamp unit used in the old days along with one of the number pins it held. Once the numbers are installed, there is a safety pin like wire that holds them in. You can see it on the stamper. Hard to see how the numbers would get out of alignment. Look at the Tonawanda stamp. Nice and straight.
http://good-times.webshots.com/photo...01686729EWMNUp
Old 03-07-2009, 04:19 AM
resto4u resto4u is offline
Old 03-07-2009, 05:04 AM
CT Mark CT Mark is offline
I think I've seen that stamp before. The vin seems fishy. Be careful if it's a car you are considering buying. There's a guy that used to be a member here that could tell you for sure. www.mysterychevelle.com
Mark
66 Chevelle SS
http://www.chevelles.com/showroom/da...velle_DL_2.jpg
Old 03-07-2009, 05:47 AM
snydes snydes is offline
Ya think!!
Steve
Old 03-07-2009, 06:09 AM
Fast67VelleN2O's Avatar
The assembly stamp looks good, vin doesn't.
Day 2 is Life.
