Old 02-19-2009, 06:05 AM
sixbrl440 sixbrl440 is offline
Default Springtime garage cleaning parts find...
...netted a couple I need help with, if y'all would.
Found a Delco Remy voltage regulator. Number worn off the box, but on the bracket reads:
1119003E It is 12V, neg ground. Forget what I got it for, years ago...
Sure wish I could I.D. all the trim rings...
Still ISO the thieves...RIP, Larry Clain
Old 02-19-2009, 08:26 AM
Default Re: Springtime garage cleaning parts find...
Hi
Many vehicles used the regulator originally.
To name a few:
1955-61 Corvette
1955-56-57 Chevrolet-Buick-Olds-Pontiac w/P/S
1958-62 Chevrolet-Buick-Olds-Pontiac w/o AC.
I think trucks from that era did too.
Check for a stamped date,right after the 12V.It will look like 7E for 1957,May.
Old 02-19-2009, 09:54 AM
Many thanks, for the quick de-coding. Looks like 6K. By your reckoning, would that be Nov, 56?
Sounds logical. Back in the day, I had a few of the vehicles you listed. Sadly, they are all gone now. Just the extras for them. Down to a Rambler and a Dodge.
Old 02-19-2009, 04:44 PM
drdave69 drdave69 is offline
Not to hijack too much but I also have a voltage regulator that needs decoding. The numbers are 12V N, 0M - 1119, 515. I used the commas to denote over/under.
Dave
1987 Grand National
Old 02-19-2009, 05:49 PM
sixbrl440
That would probably be October,1956.See below.
drdave
Those 515's were used on many,many mid 60's to early 70's GM vehicles,including utility trucks.Just too many to list from 1967-72.
Your format is typical and is dated 1970,December.
Delco-Remy avoided using the letter I in their date coding format,as it resembled the number one too closely.
Old 02-20-2009, 04:32 PM
Thanks.
Dave
1987 Grand National
Old 02-21-2009, 08:29 AM
BJCHEV396's Avatar
Mr70 you sure know your stuff!
