Old 02-17-2009, 06:38 AM
jasonL78 jasonL78 is offline
Default 67 chevelle BB motor mount help!
Ok I bought a set of BB frame mounts and motor mounts for the 67 chevelle I am doing last year off e-bay. I questioned the seller when I tried to put the 2 together and the holes didn't line up. The seller said he sells a lot of them and the weight of the motor will help the holes line up. Well that is a bunch of BS because with the motor in place this is what I ended up with. I think I have the correct frame mounts but the wrong motor mount's. Did anyone ever run into this problem and what did you do to resolve it. Not really sure what I should do. Should I try another set of motor mount's.
Driver side
Passenger side
I did learn something tonight! A 396 with a turbo 400 and a mildon 7 quart oil pan will not go into a 67 chevellle together. I even have the complete front end off the car. THen I split the 2 apart and ran into the motor mount problem.
