Old 02-09-2009, 01:56 AM
Rixls6 Rixls6 is offline
Default 69 772 fan and clutch
I have a fan and clutch assembly dated July of 69.
Is the clutch specific to certain RPO engines?
Rick
Don't text and drive.
Old 02-09-2009, 05:42 PM
Steve Shauger's Avatar
Administrator
Default Re: 69 772 fan and clutch
The cluch was specific to it application. For instance the clutch shaft length was different on BB vs SB, in addition RPM operating range called out different clutches. For instance a Z28 had a different clutch than a 307 with A/C due to rpm range. The same applied to solid lifter L78 vs L35 w/C60,K02.
www.vintagecertification.com
Old 02-09-2009, 05:51 PM
Thanks Steve.
What clutch shaft length would be correct for a 69 big block, and what would a small block be?
Rick
