Old 01-26-2009, 06:09 AM
scuncio's Avatar
scuncio scuncio is offline
Default Lightened (Acid Dipped) 65-67 GTO Hood
I have an original GM steel GTO hood that has been acid dipped to remove weight. Originally the hood weighed about 66 pounds and the acid dipping left it at about 44. The hood is super straight but there are small areas in the inner framework that went through (areas that were previously corroded). I have $200 into the acid dipping and plastic media blasting. $300 for the hood, local pickup only please.
I wanted to use this hood on my 65 Lemans but ended up making the induction system fit under the stock flat hood.
Thanks for the ad,
Tony
