Old 01-25-2009, 06:19 PM
sg1747 sg1747 is offline
Default Parts Wanted for 69Z Build Date 3rd Week of Jan.
I need the following parts for my 69Z. Build date is the 3rd week of January:
● reproduction brake booster and master cylinder cap
● incorrect exhaust manifolds and smog components, plug wire heat shields also missing
● carburetor is too early for the build date of the car, 7B1
● incorrect coil
● generic replacement voltage regulator
● 1968 reproduction wood steering wheel
● incorrect intake manifold bolts
● engine lift hooks missing
● left and right side intake manifold wire loom holders missing
● incorrect oil cap
● hood drilled for hood pins
● generic replacement water pump
● ZL-2 option added to car, reproduction air cleaner
● valve cover bolts and misc hardware is incorrect
● hood pad installed upside down, incorrect clips
● flat bead window fuzzies, very bad
● antenna base bezel is incorrect or missing
● door jams do not receive GM decals
● generic replacement fuel pump and mounting bolts
● incorrect Firestone tires and FW rally wheels
● upper cowl area painted black, should be body color
● car should not have trunk mat, does not have deluxe interior
● generic replacement rear leaf springs
● no T-bolts in rear axle mounting
● incorrect rear axle lower shock plates and hardware
● gauges added to car, no clock in dash cluster
● seats are bolted on top of carpet, not correct
● fuel tank straps should be painted semi gloss black and should NOT have rubber insulators under them
● incorrect starter motor
● brake booster hose bracket is missing
John
215-945-1984
