Old 01-21-2009, 11:07 PM
Unreal Unreal is offline
Default 69 L72 Motor mounts
Can someone tell me for sure if the mounts shown in KP's eBay ad http://cgi.ebay.com/ebaymotors/ws/eBayIS...3&viewitem= are correct for 69 L72 (or other 69 b/b for that matter)
I've been told that they are correct only for s/b. I was under the impression that they were the same for both the b/b and Z/28-SS350. (don't have an opinion on other s/b)
If they changed to the interlocking variety during the model year, when was that change made?
Old 01-22-2009, 12:30 AM
farone farone is offline
Default Re: 69 L72 Motor mounts
Those are correct for a big block.... The small block mounts are similar, but have a "J" shaped cut out at the lower hole. I have a 10A build 69 Z/28 that still have that mount in it. It was never apart. As far as the big block, I don't really know if they carried thru the entire year.
Frank
What do I know ????? I didn't write any books....
Old 01-22-2009, 12:50 AM
COPO CARTEL COPO CARTEL is offline
Wow...he is alive.
Drive it ...Like you STOLE it !!
Old 01-22-2009, 01:05 AM
Hey Frank,
Thanks for the info. What do you mean by the lower hole? Also do you mean a J shaped cut-out in the metal? Out of curiosity, what is the purpose of the cut-out? Do you know if the dimensions are the same? ie do they interchange?
I have a set like the ones KP had on ebay, and a guy told me they were incorrect for b/b. I was thinking maybe the change was made in the model year, so maybe that was the discrepancy. I do know that I had mine on my b/b for 200 miles, and that everything aligned. When I re-installed my engine, I went with the aftermarket interlocking ones, and they have caused my engine to be about 1/8" lower, and now I have to remove the crank pulley to get the belts on. Fortunately the belts and pulley do not hit the crossmember.
Thanks again, and Go Steelers!!! (or as we pronounce it in Pittsburgh, Go Stiilers!)
Old 01-22-2009, 05:08 AM
The "J" shape cut out is in the rubber, not the metal. I will try to post pics tomorrow.
Frank
Old 01-22-2009, 04:21 PM
Big block mount
Old 01-22-2009, 04:23 PM
Small block mount
Old 01-22-2009, 08:23 PM
pSYCo pSYCo is offline
if you look at the other side of the mounts ( that faces the block ) the SMALL BLOCK mounts have a ''L'' shape formed into the metal, while the BIG block mounts have a '' T'' shape.....IMHO.......
Old 01-23-2009, 03:09 AM
Well, thanks for the info. I guess my NOS "big block" mounts are really small block.
Old 01-23-2009, 02:54 PM
leach's Avatar
leach leach is offline
Does anyone have set of these for sale
Barry White
1970 Nickey Converted 427 Nova SS 4 speed
1965 Chevelle SS L79 4 speed
