Old 01-21-2009, 05:38 PM
Default Fan Shroud Restore
I have two fan shrouds. One has a good top & bottom (top has the dreaded Caution Fan) the other is correct used and the top is in excellent shape (No Caution Fan)but the bottom has a crack.
Question,
The pieces appear to be held together by staples. Are the staples the only positive connection between the two pieces of are they also glued or butt welded? I want to try to separate them and put together a correct shroud.
Also does anyone have any suggestions for new staples or other for the reassembly???
Thanks
Carl
Old 01-21-2009, 08:21 PM
DarrenX33's Avatar
Default Re: Fan Shroud Restore
Good question Carl.. I also would like to know how to repair a shroud that has an unwanted screw hole in it..
1969 Z28
1972 Corvette
Old 01-21-2009, 08:52 PM
Carl, The two halves of the 70+ Small Block fan shrouds are ONLY stapled together.
I have never tried to make my own staples........but have read where others have taken "wire" and done so....
Hopefully someone else can offer specific instructions.
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 01-21-2009, 08:55 PM
ORIGLS6 ORIGLS6 is offline
Check with Dru. We had a plastic tank here in the plant that developed a leak. We contacted a local body man who brought in a "Plastic Welder" and repaired the tank. If I recall correctly he had different types, sizes and colors of "rods" he could use for various applications. Seems like he told me they also repaired the plastic bumper covers in some cases. Might be worth looking into.
Old 01-21-2009, 10:32 PM
Darren, I dont think filling the screw hole will be that big of a challenge. As has been mentioned "welding" or using a catalized product will solve that problem.
I think that refinishing the surface is the difficult part.
Coming up with a paint that simulates the "LOOK" of the OEM plastic is the challenge.
Jeff Betz has detailed instructions, when he refinished the A/C firewall "suitcase" on his 77 Z-28 resto. His methods and techniques, however didnt have to deal with covering the filling in of a hole.
Chuck Sharin
[email protected]
Old 01-21-2009, 10:33 PM
Bad Brad Bad Brad is offline
Have you tried to fill the hole with a small piece of plastic (same material) as the fan shroud. Then use some MEK to soften it up and weld itself in the hole then lightly sand it and polish the plastic.
" NO Replacement For Displacement" Any Questions?
TC # 2747 ACES # 7166
Old 01-21-2009, 10:45 PM
Unreal Unreal is offline
I used stainless wire to make staples for my splash shields. They are somewhat more shiny than original steel, but they will not rust. Depends on what you want for your shroud. Too shiny vs rusty in short order
Old 01-22-2009, 01:35 AM
I've been told that suitable staples can be found in 67-69 inner fender dust shield kits.
I also seem to remember talking to 70 copo at the last SCR about painting my existing shroud but I cant remember what he said??
Dang
Carl
Old 01-26-2009, 03:11 PM
lzdick lzdick is offline
The staples that come with the splash shields are very rigid and difficult to work with. Go to your local offic supply and get the larger paper clips (1 7/8"). They bend easily and are the correct gauge.
L.Z.
"...at this point in my life, every day is a Saturday".
Old 01-26-2009, 07:10 PM
Cool thanks!
Carl
