Old 01-19-2009, 09:01 PM
sg1747 sg1747 is offline
Default Dash Clock
I just purchase a 69 Z-28 that does not have the dash clock between the tach and speedometer. Can someone tell me if the blank piece of plastic will come out in order to install the clock?
John
Old 01-19-2009, 09:43 PM
Ngtflyr Ngtflyr is offline
Default Re: Dash Clock
I had to cut mine out. I borrowed one with the cutout for a template. Started by cutting out a slightly smaller hole using a utility knife. I then used a dremel tool to expand the hole to the same size as the template. Then used sandpaper to smooth it out.
Dave
Old 01-19-2009, 10:17 PM
wow that sounds like some thing i would mess up.
john
Old 01-19-2009, 11:29 PM
jeff morocco jeff morocco is offline
john
john, if you can build/maintain that sg car, you'll do fine.
