Old 12-16-2008, 08:51 PM
Jeff Murphy Jeff Murphy is offline
Default Deep sump pan question
There was a thread around here previously discussing deep sump pans found on the Gibb Novas and the green Dana Camaro. Can you guys look at the photos below and let me know if you think the black pan will fit on a 69 Camaro with manual steering?
Jeff M.
ZL1 #49 (Dale, Waukesha WI) Super Stock restoration by SCW; 9561AA (Walters, Hebron OH) Super Stock motor by the Grump
Old 12-16-2008, 10:18 PM
farone farone is offline
Default Re: Deep sump pan question
No ????
What do I know ????? I didn't write any books....
Old 12-17-2008, 12:42 AM
Frank would know better than me but I've got Annie's car here in the shop with the correct deep sump pan and it looks somewhat similar to your deep sump in the area of the middle hump.
Hmmmmm, wonder whose engine shop that is........
Old 12-17-2008, 02:45 AM
Yes it will fit.
Jake is my grandson!!
Old 12-17-2008, 02:49 AM
mockingbird812's Avatar
Concur with Mr. Howie, however, it might be smart to secure roller skate wheels to the bottom.
Sam...
Old 12-17-2008, 02:51 AM
Same double hump as the pan used on the Gibb nova. Org motor with the pan.
Old 12-17-2008, 02:54 AM
Jeff take a measurement from the top of pan to bottom. Let me know what it is. Kim
Old 12-17-2008, 02:56 AM
Yeah and I'll start lining up different height roller skate wheels.................
Sam...
Old 12-17-2008, 07:42 PM
Tommy Tommy is offline
I was running this on my 68 Nova with no problems. It appears to be about the same depth. since the Nova and Camaro have the same front subframe you should have no problem at all with yours as long as you get that front end up a little
This one fits fine on my 72 Nova. Its the early Moroso with the drain plug in the bottom of the pan instead of the corner.
Tommy
